주요 콘텐츠로 건너뛰기
LeapFrog LeapPad Ultimate Camera Replacement
필요한 것
  1. LeapFrog LeapPad Ultimate Camera Replacement, Back Panel: 1 단계, 이미지 1/2 LeapFrog LeapPad Ultimate Camera Replacement, Back Panel: 1 단계, 이미지 2/2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Camera Replacement: 2 단계, 이미지 1/2 LeapFrog LeapPad Ultimate Camera Replacement: 2 단계, 이미지 2/2
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
  3. LeapFrog LeapPad Ultimate Camera Replacement, Camera: 3 단계, 이미지 1/1
    • Remove the 3 screws on each corner of the motherboard
  4. LeapFrog LeapPad Ultimate Camera Replacement: 4 단계, 이미지 1/3 LeapFrog LeapPad Ultimate Camera Replacement: 4 단계, 이미지 2/3 LeapFrog LeapPad Ultimate Camera Replacement: 4 단계, 이미지 3/3
    • Remove the ribbon on the bottom of the motherboard and the ribbon on the left side of the motherboard.
    • There will be a small black switch on top of the ribbons that you must flip to take them out.
  5. LeapFrog LeapPad Ultimate Camera Replacement: 5 단계, 이미지 1/1
    • Remove the 3-pin connector on the top left side of the motherboard.
  6. LeapFrog LeapPad Ultimate Camera Replacement: 6 단계, 이미지 1/2 LeapFrog LeapPad Ultimate Camera Replacement: 6 단계, 이미지 2/2
    • Flip the motherboard to its back side and pinch the 2 green hooks to remove the camera cover
  7. LeapFrog LeapPad Ultimate Camera Replacement: 7 단계, 이미지 1/1
    • Remove the ribbon connecting the camera to the motherboard. You have now taken out the camera and can replace it with a new one.
결론
Nabil Mustafa
회원 가입일: 09/21/18
223 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 209
