주요 콘텐츠로 건너뛰기
LeapFrog LeapPad Ultimate LCD Screen Replacement
필요한 것
  1. LeapFrog LeapPad Ultimate LCD Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 LeapFrog LeapPad Ultimate LCD Screen Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 LeapFrog LeapPad Ultimate LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
  3. LeapFrog LeapPad Ultimate LCD Screen Replacement, LCD Screen: 3 단계, 이미지 3개 중 1개 LeapFrog LeapPad Ultimate LCD Screen Replacement, LCD Screen: 3 단계, 이미지 3개 중 2개 LeapFrog LeapPad Ultimate LCD Screen Replacement, LCD Screen: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • The segment connecting the battery to the motherboard will consist of red, white, and black wires.
    • There is a small notch on the segment. Use the curved tweezers to pull the notch in the direction of the battery. this will disconnect the battery from the motherboard.
    • The battery is the bright orange rectangle.
    • The motherboard is the large dark green surface.
  4. LeapFrog LeapPad Ultimate LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully remove the battery from its place and set aside.
    • Removing the battery will fully expose a white and blue ribbon cable that runs beneath the battery.
    • The ribbon cable must be disconnected from the motherboard and removed from the panel.
  5. LeapFrog LeapPad Ultimate LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 LeapFrog LeapPad Ultimate LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    • The ZIF connector which connects the ribbon cable and the motherboard has a small flap on the top.
    • Use the curved tweezers to to flip the flap up.
    • Once it is disconnected, carefully pull the ribbon cable through the 2 black plastic arches holding it down.
  6. LeapFrog LeapPad Ultimate LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to unscrew the 7 screws on the speaker.
    • 5 will be on the brown part and 2 on the circular blur part.
    • Once it is unscrewed completely, remove the speaker and set aside.
  7. LeapFrog LeapPad Ultimate LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • An orange and black ribbon cable connects the motherboard and the area to the side of the panel.
    • There is a switch on top of it.
    • Use the curved tweezers to flip the switch.
  8. LeapFrog LeapPad Ultimate LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew the 3 screws on the motherboard with a Phillips #1 screwdriver.
  9. LeapFrog LeapPad Ultimate LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 LeapFrog LeapPad Ultimate LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Flip the motherboard over to expose the uderside.
    • There is a wide black ribbon with a swtich. Flip the switch and set aside the motherboard.
  10. LeapFrog LeapPad Ultimate LCD Screen Replacement: 10 단계, 이미지 2개 중 1개 LeapFrog LeapPad Ultimate LCD Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Along the side of the blue panel are 6 screws. Unscrew each of the screws with a Phillips #1 screwdriver.
    • Remove the panel and the remainder of its contents and set aside.
  11. LeapFrog LeapPad Ultimate LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
    • The screen is now exposed and can be removed and replaced.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Avery Dillon
회원 가입일: 09/21/18
232 평판
안내서 1개를 작성함
1가이드 댓글
Where did you find a Replacement screen? Are there any identifying part numbers?
Johan Rodriguez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 38
전체 시간: 5,167
