주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
To replace the battery is a mild task to get to and can take up to 15 minutes to complete. A far warning, patience is key because the device itself is difficult to open . The only tools that will be needed will be a screwdriver and some tweezers .
  1. Flip over the Pad to its back side to begin the removal of the back panel. Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. Once the blue rim is removed, the 12 screws will be visible. Use the Phillips #1 screwdriver to unscrew all 12 screws.
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
  3. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  4. Begin with the removal of  the battery from its place. Flip the black switch that is connecting the battery to the motherboard.
    • Begin with the removal of the battery from its place.
    • Flip the black switch that is connecting the battery to the motherboard.
    • Then pull gently and should disconnect.
  5. Remove the black and white ribbon structures from the side of the motherboard. Next, remove the three screws along the corners of the motherboard using the Phillips # 1 screwdriver. Next, remove the three screws along the corners of the motherboard using the Phillips # 1 screwdriver.
    • Remove the black and white ribbon structures from the side of the motherboard.
    • Next, remove the three screws along the corners of the motherboard using the Phillips # 1 screwdriver.
  6. Use a Phillips #1 screwdriver to unscrew the 7  screws  from the speaker with the  bronze plate sound board.
    • Use a Phillips #1 screwdriver to unscrew the 7 screws from the speaker with the bronze plate sound board.
    • Unscrew the 8 screws from the blue sub-panel.
  7. Take off the sub-panel exposing the motherboard. Flip the motherboard on its back side and flip the switch to remove the wide orange ribbon and  pull the twisted black and white wires from its place.
    • Take off the sub-panel exposing the motherboard.
    • Flip the motherboard on its back side and flip the switch to remove the wide orange ribbon and pull the twisted black and white wires from its place.
결론
Fernando Lozano-Garcia
회원 가입일: 2018년 09월 21일
347 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 214
