이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip over the Pad to its back side to begin the removal of the back panel.
Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
Once the blue rim is removed, the 12 screws will be visible.
Use the Phillips #1 screwdriver to unscrew all 12 screws.
Begin with the removal of the battery from its place.
Flip the black switch that is connecting the battery to the motherboard.
Then pull gently and should disconnect.
Remove the black and white ribbon structures from the side of the motherboard.
Next, remove the three screws along the corners of the motherboard using the Phillips # 1 screwdriver.
Use a Phillips #1 screwdriver to unscrew the 7 screws from the speaker with the bronze plate sound board.
Unscrew the 8 screws from the blue sub-panel.
Take off the sub-panel exposing the motherboard.
Flip the motherboard on its back side and flip the switch to remove the wide orange ribbon and pull the twisted black and white wires from its place.
