주요 콘텐츠로 건너뛰기
LeapFrog LeapPad Ultra Repair Motherboard Replacement
필요한 것
  1. LeapFrog LeapPad Ultra Repair Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Motherboard Replacement: 3 단계, 이미지 1/1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapFrog LeapPad Ultra Repair Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapFrog LeapPad Ultra Repair Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Motherboard Replacement: 6 단계, 이미지 1/2 LeapFrog LeapPad Ultra Repair Motherboard Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  7. LeapFrog LeapPad Ultra Repair Motherboard Replacement, Motherboard: 7 단계, 이미지 1/3 LeapFrog LeapPad Ultra Repair Motherboard Replacement, Motherboard: 7 단계, 이미지 2/3 LeapFrog LeapPad Ultra Repair Motherboard Replacement, Motherboard: 7 단계, 이미지 3/3
    • Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
  8. LeapFrog LeapPad Ultra Repair Motherboard Replacement: 8 단계, 이미지 1/1
    • Unscrew the five screws holding the motherboard into the housing.
  9. LeapFrog LeapPad Ultra Repair Motherboard Replacement: 9 단계, 이미지 1/3 LeapFrog LeapPad Ultra Repair Motherboard Replacement: 9 단계, 이미지 2/3 LeapFrog LeapPad Ultra Repair Motherboard Replacement: 9 단계, 이미지 3/3
    • Lift the motherboard up exposing the fourth and final wire. Once you lift up the motherboard you will need to pull down on the wire to disconnect.
  10. LeapFrog LeapPad Ultra Repair Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove and replace motherboard.
결론
Rocky Hirsch
회원 가입일: 08/27/15
848 평판
안내서 3개 작성하였습니다
USF Tampa, Team 4-99, Meier Fall 2015 USF Tampa, Team 4-99, Meier Fall 2015 회원
USFT-MEIER-F15S4G99
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 21
전체 시간: 1,564
