주요 콘텐츠로 건너뛰기
LeapFrog LeapPad Ultra Repair Speaker Replacement
필요한 것
  1. LeapFrog LeapPad Ultra Repair Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Speaker Replacement: 3 단계, 이미지 1/1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapFrog LeapPad Ultra Repair Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapFrog LeapPad Ultra Repair Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Speaker Replacement: 6 단계, 이미지 1/2 LeapFrog LeapPad Ultra Repair Speaker Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  7. LeapFrog LeapPad Ultra Repair Speaker Replacement, Speaker: 7 단계, 이미지 1/1
    • Find the screws on the bottom of the device holding down the button and speakers board.
  8. LeapFrog LeapPad Ultra Repair Speaker Replacement: 8 단계, 이미지 1/2 LeapFrog LeapPad Ultra Repair Speaker Replacement: 8 단계, 이미지 2/2
    • There should be a plastic covering over the speaker, carefully pull on the opposite side from the plastic clip holding it in place.
    • Excessive force can break the plastic clip, only use enough for to remove it gently
  9. LeapFrog LeapPad Ultra Repair Speaker Replacement: 9 단계, 이미지 1/2 LeapFrog LeapPad Ultra Repair Speaker Replacement: 9 단계, 이미지 2/2
    • Lift the button and speaker board, and turn it over, revealing the other side of the board.
  10. LeapFrog LeapPad Ultra Repair Speaker Replacement: 10 단계, 이미지 1/2 LeapFrog LeapPad Ultra Repair Speaker Replacement: 10 단계, 이미지 2/2
    • Find the ribbon cable connection and with a small plastic tool flip the plastic holding it down up.
    • You can now safely remove the ribbon cable by gently pulling it out of the slot.
    • Trying to remove the cable with brute force will damage the cable.
결론
Carlos Ortiz
회원 가입일: 08/24/15
219 평판
안내서 1개 작성함
USF Tampa, Team 4-99, Meier Fall 2015 USF Tampa, Team 4-99, Meier Fall 2015 회원
USFT-MEIER-F15S4G99
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Where can i buy a replacement speaker at to do this?
anthonydesiato2002 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,003
