주요 콘텐츠로 건너뛰기
LeapFrog LeapPad2 Explorer Back Cover Replacement
필요한 것
  1. LeapFrog LeapPad2 Explorer Back Cover Replacement, Battery: 1 단계, 이미지 1/2 LeapFrog LeapPad2 Explorer Back Cover Replacement, Battery: 1 단계, 이미지 2/2
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Back Cover Replacement: 2 단계, 이미지 1/3 LeapFrog LeapPad2 Explorer Back Cover Replacement: 2 단계, 이미지 2/3 LeapFrog LeapPad2 Explorer Back Cover Replacement: 2 단계, 이미지 3/3
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Back Cover Replacement, Back Cover: 3 단계, 이미지 1/2 LeapFrog LeapPad2 Explorer Back Cover Replacement, Back Cover: 3 단계, 이미지 2/2
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Back Cover Replacement: 4 단계, 이미지 1/3 LeapFrog LeapPad2 Explorer Back Cover Replacement: 4 단계, 이미지 2/3 LeapFrog LeapPad2 Explorer Back Cover Replacement: 4 단계, 이미지 3/3
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
결론
Nupur Garg
회원 가입일: 04/12/14
867 평판
안내서 7개 작성하였습니다
Cal Poly, Team 8-10, Regan Spring 2014 Cal Poly, Team 8-10, Regan Spring 2014 회원
CPSU-REGAN-S14S8G10
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,408
