주요 콘텐츠로 건너뛰기
LeapFrog LeapTV Controller Button Replacement
필요한 것
  1. LeapFrog LeapTV Controller Button Replacement, Battery: 1 단계, 이미지 1/1
    • Use the Metal Spudger to push the release clip on the battery cover.
  2. LeapFrog LeapTV Controller Button Replacement: 2 단계, 이미지 1/1
    • Lift the cover off.
  3. LeapFrog LeapTV Controller Button Replacement: 3 단계, 이미지 1/1
    • The battery holder is now visible with the removal of the cover.
  4. LeapFrog LeapTV Controller Button Replacement, Buttons: 4 단계, 이미지 1/1
    • Use the screwdriver to remove the eight 8.7mm PH1 Phillips head screws.
  5. LeapFrog LeapTV Controller Button Replacement: 5 단계, 이미지 1/1
    • Slightly lift up on the back cover until the handle covers are free to rotate.
  6. LeapFrog LeapTV Controller Button Replacement: 6 단계, 이미지 1/1
    • Slide the the side of the handle facing you to the left to reveal the "A" and "B" button circuit board.
  7. LeapFrog LeapTV Controller Button Replacement: 7 단계, 이미지 1/1
    • Use the screwdriver to remove the three 8.5mm PH1 Phillips head screws.
  8. LeapFrog LeapTV Controller Button Replacement: 8 단계, 이미지 1/1
    • Lift up on the circuit board and move it to the side.
    • Be careful to not cause excess stress to the connecting wires when handling the circuit board. Excess stress can cause solder points to break.
  9. LeapFrog LeapTV Controller Button Replacement: 9 단계, 이미지 1/1
    • Use the plastic opening tool to release the buttons from the controller casing.
  10. LeapFrog LeapTV Controller Button Replacement: 10 단계, 이미지 1/1
    • Remove the "A" and "B" buttons by pulling up on one of the buttons.
  11. LeapFrog LeapTV Controller Button Replacement: 11 단계, 이미지 1/1
    • Buttons are now removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Triston Fischer
회원 가입일: 03/08/17
128 평판
안내서 1개 작성함
IUPUI, Team S4-G2, Baechle Spring 2017 IUPUI, Team S4-G2, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S4G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 357
