주요 콘텐츠로 건너뛰기
LeapFrog LeapTV Controller Joy Stick Replacement
필요한 것
  1. LeapFrog LeapTV Controller Joy Stick Replacement, Battery: 1 단계, 이미지 1/1
    • Use the Metal Spudger to push the release clip on the battery cover.
  2. LeapFrog LeapTV Controller Joy Stick Replacement: 2 단계, 이미지 1/1
    • Lift the cover off.
  3. LeapFrog LeapTV Controller Joy Stick Replacement: 3 단계, 이미지 1/1
    • The battery holder is now visible with the removal of the cover.
  4. LeapFrog LeapTV Controller Joy Stick Replacement, Controller Joy Stick: 4 단계, 이미지 1/1
    • Use the screwdriver to remove the eight 8.7 mm PH1 Phillips head screws.
  5. LeapFrog LeapTV Controller Joy Stick Replacement: 5 단계, 이미지 1/1
    • Separate the top and bottom parts of the controller slightly.
  6. LeapFrog LeapTV Controller Joy Stick Replacement: 6 단계, 이미지 1/1
    • Slide the cover on the back side of the controller covering the joy stick out of the way.
  7. LeapFrog LeapTV Controller Joy Stick Replacement: 7 단계, 이미지 1/1
    • Use the screwdriver to remove the four 8.7 mm PH1 Phillips head screws.
  8. LeapFrog LeapTV Controller Joy Stick Replacement: 8 단계, 이미지 1/1
    • Turn and lift the circuit board with button attacked out of the hole. Do not detach the circuit.
  9. LeapFrog LeapTV Controller Joy Stick Replacement: 9 단계, 이미지 1/1
    • Hold the circuit board and button and pull the button off.
  10. LeapFrog LeapTV Controller Joy Stick Replacement: 10 단계, 이미지 1/1
    • Joystick will now pop off.
결론
Joshua Jones
회원 가입일: 03/23/17
101 평판
안내서 1개 작성함
IUPUI, Team S4-G2, Baechle Spring 2017 IUPUI, Team S4-G2, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S4G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 764
