주요 콘텐츠로 건너뛰기
LeapFrog Scribble and Write Eraser Slider Cleaning
필요한 것
  1. LeapFrog Scribble and Write Eraser Slider Cleaning, Eraser Slider: 1 단계, 이미지 1개 중 1개
    • Turn the toy over so the back is facing upward.
  2. LeapFrog Scribble and Write Eraser Slider Cleaning: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, carefully remove all 9 screws.
    • Set aside screws in a safe place for later reassembly.
  3. LeapFrog Scribble and Write Eraser Slider Cleaning: 3 단계, 이미지 1개 중 1개
    • Remove the back of the toy by carefully lifting it up.
  4. LeapFrog Scribble and Write Eraser Slider Cleaning: 4 단계, 이미지 2개 중 1개 LeapFrog Scribble and Write Eraser Slider Cleaning: 4 단계, 이미지 2개 중 2개
    • Using a Phillips #0 screwdriver, remove the two screws that secure the screen to the motherboard.
    • Set aside screws in a safe place.
    • Gently remove the motherboard to expose the display screen and eraser slider.
  5. LeapFrog Scribble and Write Eraser Slider Cleaning: 5 단계, 이미지 1개 중 1개
    • Carefully remove the display screen, leaving the eraser slider attached.
  6. LeapFrog Scribble and Write Eraser Slider Cleaning: 6 단계, 이미지 2개 중 1개 LeapFrog Scribble and Write Eraser Slider Cleaning: 6 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove the eraser slider.
  7. LeapFrog Scribble and Write Eraser Slider Cleaning: 7 단계, 이미지 1개 중 1개
    • Lastly, use a soft towel to clean the eraser slider, removing any debris.
    • When all previous seven steps are completed, go backwards and re-screw and put together your The LeapFrog Scribble and Write
결론
작성자
9다른 기여자 명과 함께
Shang
회원 가입일: 02/10/16
328 평판
안내서 3개를 작성함
USF Tampa, Team 1-5, Nance Spring 2016 USF Tampa, Team 1-5, Nance Spring 2016 회원
USFT-NANCE-S16S1G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 3
지난 30일: 7
전체 시간: 951
