주요 콘텐츠로 건너뛰기
LeapFrog Scribble and Write Motherboard Replacement
필요한 것
  1. LeapFrog Scribble and Write Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Use a Phillips head screwdriver to remove the screw from the battery compartment on the back of the toy.
  2. LeapFrog Scribble and Write Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the back battery cover and all of the batteries.
  3. LeapFrog Scribble and Write Motherboard Replacement: 3 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
    • Be careful to keep track of the screws.
  4. LeapFrog Scribble and Write Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the back cover from your toy.
  5. LeapFrog Scribble and Write Motherboard Replacement: 5 단계, 이미지 1/1
    • Using a Phillips screwdriver, remove the four screws from the motherboard.
  6. LeapFrog Scribble and Write Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the keyboard ribbon from the motherboard.
  7. LeapFrog Scribble and Write Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the speaker wires from the motherboard with your soldering iron.
  8. LeapFrog Scribble and Write Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the battery wires from the motherboard with the soldering iron.
  9. LeapFrog Scribble and Write Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the switch wires from the motherboard with the soldering iron.
  10. LeapFrog Scribble and Write Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the pen wires from the motherboard with the soldering iron.
  11. LeapFrog Scribble and Write Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove the volume control switch from the motherboard with the soldering iron.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Shang
회원 가입일: 02/10/16
328 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-5, Nance Spring 2016 USF Tampa, Team 1-5, Nance Spring 2016 회원
USFT-NANCE-S16S1G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 641
