주요 콘텐츠로 건너뛰기
LeapPad Ultra Battery Replacement
필요한 것
  1. LeapPad Ultra Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapPad Ultra Battery Replacement: 2 단계, 이미지 1/1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapPad Ultra Battery Replacement: 3 단계, 이미지 1/1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapPad Ultra Battery Replacement: 4 단계, 이미지 1/1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapPad Ultra Battery Replacement: 5 단계, 이미지 1/1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapPad Ultra Battery Replacement: 6 단계, 이미지 1/2 LeapPad Ultra Battery Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
결론
To reassemble the device, follow these instructions in reverse order.
다른 7명이 해당 안내서를 완성하였습니다.
Ryan Arredondo
회원 가입일: 08/31/15
246 평판
안내서 1개 작성함
USF Tampa, Team 4-99, Meier Fall 2015 USF Tampa, Team 4-99, Meier Fall 2015 회원
USFT-MEIER-F15S4G99
4 회원들
안내서 10개 작성하였습니다
댓글 4개
Hi Ryan, will removing the battery delete any of the downloaded apps and saved files?
Michael - 답글
I’m not Ryan, but I just did this process and the apps and files are all still there.
Kivi Shapiro - 답글
What is a spudger and where do I get a battery
P Mac - 답글
Hello, if anyone still has this leappad Ultra and wanted to purchase a new battery. I have found a retail store https://batteryclerk.com/ The price is reasonable, and I'm just waiting for the batteries to arrive.
Mike Silva - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 43
전체 시간: 16,146
