소개
To replace the battery you will need a replacement. Once you have the battery, following this guide will lead you to a fully functioning device.
필요한 것
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
다른 3명이 해당 안내서를 완성하였습니다.
