주요 콘텐츠로 건너뛰기
Leapfrog LeapPad 3 Motherboard Replacement
필요한 것
  1. Leapfrog LeapPad 3 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Leapfrog LeapPad 3 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Leapfrog LeapPad 3 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.16
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Leapfrog LeapPad 3 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Leapfrog LeapPad 3 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Leapfrog LeapPad 3 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
  4. Leapfrog LeapPad 3 Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Leapfrog LeapPad 3 Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
    • Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
  5. Leapfrog LeapPad 3 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Leapfrog LeapPad 3 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Leapfrog LeapPad 3 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
  6. Leapfrog LeapPad 3 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Leapfrog LeapPad 3 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Leapfrog LeapPad 3 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
    • Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
    • The device was rotated 180 degrees in order to unplug the display assembly cord.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Matt Irvine
회원 가입일: 02/04/16
952 평판
안내서 6개를 작성함
USF Tampa, Team 16-2, Blackwell Winter 2016 USF Tampa, Team 16-2, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G2
3 회원들
안내서 12개를 작성함
1가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 1,630
