주요 콘텐츠로 건너뛰기
Leapfrog LeapPad 3 Speaker Replacement
필요한 것
  1. Leapfrog LeapPad 3 Speaker Replacement, Battery: 1 단계, 이미지 1/3 Leapfrog LeapPad 3 Speaker Replacement, Battery: 1 단계, 이미지 2/3 Leapfrog LeapPad 3 Speaker Replacement, Battery: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Speaker Replacement: 2 단계, 이미지 1/3 Leapfrog LeapPad 3 Speaker Replacement: 2 단계, 이미지 2/3 Leapfrog LeapPad 3 Speaker Replacement: 2 단계, 이미지 3/3
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Speaker Replacement: 3 단계, 이미지 1/2 Leapfrog LeapPad 3 Speaker Replacement: 3 단계, 이미지 2/2
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
  4. Leapfrog LeapPad 3 Speaker Replacement, Speaker: 4 단계, 이미지 1/2 Leapfrog LeapPad 3 Speaker Replacement, Speaker: 4 단계, 이미지 2/2
    • Disconnect the audio cord from the motherboard using a plastic opening tool.
    • When re-plugging this cord be sure it is flush with the slot, otherwise the speaker and directional pad will malfunction.
    • Use caution when unplugging, and re-plugging the ribbon cord as they are fragile.
  5. Leapfrog LeapPad 3 Speaker Replacement: 5 단계, 이미지 1/3 Leapfrog LeapPad 3 Speaker Replacement: 5 단계, 이미지 2/3 Leapfrog LeapPad 3 Speaker Replacement: 5 단계, 이미지 3/3
    • Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
  6. Leapfrog LeapPad 3 Speaker Replacement: 6 단계, 이미지 1/3 Leapfrog LeapPad 3 Speaker Replacement: 6 단계, 이미지 2/3 Leapfrog LeapPad 3 Speaker Replacement: 6 단계, 이미지 3/3
    • Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
    • Remove the board and speaker from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Matt Irvine
회원 가입일: 02/04/16
952 평판
안내서 6개 작성하였습니다
USF Tampa, Team 16-2, Blackwell Winter 2016 USF Tampa, Team 16-2, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S16G2
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
Where can I purchase a replacement audio board /speaker for the LeapPad3?
lizchilds - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 887
