주요 콘텐츠로 건너뛰기
Leapfrog My Own Leaptop Battery Replacement Guide
필요한 것
  1. Leapfrog My Own Leaptop Battery Replacement Guide, Battery: 1 단계, 이미지 1/1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Battery Replacement Guide: 2 단계, 이미지 1/1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Battery Replacement Guide: 3 단계, 이미지 1/2 Leapfrog My Own Leaptop Battery Replacement Guide: 3 단계, 이미지 2/2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan Fitzer
회원 가입일: 02/10/16
584 평판
안내서 3개 작성하였습니다
USF Tampa, Team 14-6, Lacy Spring 2016 USF Tampa, Team 14-6, Lacy Spring 2016 회원
USFT-LACY-S16S14G6
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Hi Jonathan! Your article is very helpful. But I have a big question now. I have opened the leaptop and see that membrane should be replaced. But where can I buy the membrane separately? Please help!
Alina Timchenko - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 66
전체 시간: 2,926
