주요 콘텐츠로 건너뛰기
Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide
필요한 것
  1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Battery: 1 단계, 이미지 1/1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 2 단계, 이미지 1/1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 3 단계, 이미지 1/2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 3 단계, 이미지 2/2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Keyboard Buttons: 4 단계, 이미지 1/1
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 5 단계, 이미지 1/1
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 6 단계, 이미지 1/2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 6 단계, 이미지 2/2
    • Remove the three 10mm screws from the upper left hand corner white plastic piece with a PH1 phillips head screwdriver.
    • Unscrew the five 4mm screws from the plastic membrane with a PH1 phillips head screwdriver.
  7. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 7 단계, 이미지 1/1
    • Remove the white plastic piece and place it to the side.
  8. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 8 단계, 이미지 1/3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 8 단계, 이미지 2/3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 8 단계, 이미지 3/3
    • Gently grab the membrane and peal it upwards.
    • Carefully remove the membrane and set it to the side.
    • From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
    • Ensure that the membrane is completely dry before reassembly.
  9. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 9 단계, 이미지 1/2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 9 단계, 이미지 2/2
    • Gently lift and remove the foam piece
  10. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 10 단계, 이미지 1/3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 10 단계, 이미지 2/3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 10 단계, 이미지 3/3
    • From here, each button is able to be removed for cleaning or replacement.
    • Using a tweezers or needle nose pliers, remove the necessary pieces from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jonathan Fitzer
회원 가입일: 02/10/16
584 평판
안내서 3개 작성하였습니다
USF Tampa, Team 14-6, Lacy Spring 2016 USF Tampa, Team 14-6, Lacy Spring 2016 회원
USFT-LACY-S16S14G6
4 회원들
안내서 6개 작성하였습니다
댓글 6개
Very useful. but where to get a new membrane? please help
Alina Timchenko - 답글
Didn't work. I'll buy a new toy.
victoria_nglover19 - 답글
Is the screen on this suppose to light up?
stewartmelinda41 - 답글
I was wondering if the screen is suppose to light up because the one I have doesnt
thank you very much
Njabulo Mbele - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 26
전체 시간: 5,162
