소개
The step by step guide is designed to assist with button replacement of the Leapfrog My Own Leaptop.
필요한 것
Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
Gently grab the membrane and peal it upwards.
Carefully remove the membrane and set it to the side.
From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
Ensure that the membrane is completely dry before reassembly.
Where can i buy the replacement membran? Only letter I and R work
Hery halim - 답글
Looks like you having same issue with me Hery.. the membrane is going hirewire. how to fix? can we do the cleaning / where to buy the membrane for replacement
Anne Tohar - 답글
다른 2명이 해당 안내서를 완성하였습니다.
댓글 6개
Very useful. but where to get a new membrane? please help
Didn't work. I'll buy a new toy.
Is the screen on this suppose to light up?
I was wondering if the screen is suppose to light up because the one I have doesnt
thank you very much
Where can you buy the membrane?
