주요 콘텐츠로 건너뛰기
Leapfrog My Own Leaptop Speaker Replacement Guide
필요한 것
  1. Leapfrog My Own Leaptop Speaker Replacement Guide, Battery: 1 단계, 이미지 1/1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Speaker Replacement Guide: 2 단계, 이미지 1/1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Speaker Replacement Guide: 3 단계, 이미지 1/2 Leapfrog My Own Leaptop Speaker Replacement Guide: 3 단계, 이미지 2/2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Speaker Replacement Guide, Speaker: 4 단계, 이미지 1/1
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Speaker Replacement Guide: 5 단계, 이미지 1/1
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Speaker Replacement Guide: 6 단계, 이미지 1/2 Leapfrog My Own Leaptop Speaker Replacement Guide: 6 단계, 이미지 2/2
    • Unscrew the two 7.5 mm screws to the left and right of the speaker with a PH1 phillips head screwdriver.
    • Remove the cover and place to the side.
  7. Leapfrog My Own Leaptop Speaker Replacement Guide: 7 단계, 이미지 1/2 Leapfrog My Own Leaptop Speaker Replacement Guide: 7 단계, 이미지 2/2
    • Once the cover is removed, gently lift up the speaker making sure not to rip or break the wires.
    • If you are disassembling the device to clean the speaker, clean it at this point with a soft, lightly dampened cloth.
    • Gently turn the speaker over and carefully desolder the white and yellow wires from the speaker.
결론
Any issues that cannot be resolved with any portion of this wiki please contact Leapfrog Customer Serivce
다른 3명이 해당 안내서를 완성하였습니다.
Jonathan Fitzer
회원 가입일: 02/10/16
584 평판
안내서 3개 작성하였습니다
USF Tampa, Team 14-6, Lacy Spring 2016 USF Tampa, Team 14-6, Lacy Spring 2016 회원
USFT-LACY-S16S14G6
4 회원들
안내서 6개 작성하였습니다
댓글 5개
Thanks for this very useful instruction. Where can I buy a replacement speaker?
-Don
Don La - 답글
I agree, but I also second the question...where can I buy a replacement speaker?
Jimmy Liang - 답글
Where could I purchase a replacement speaker?
Zuzi - 답글
Where could I buy the replacement speaker in Malaysia?
stanley.met - 답글
Where can I buy replacement speaker in Malaysia? Appreciate yr reply
ribenabona - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 29
전체 시간: 6,692
