소개
This guide will show the user how to access and clean or replace the speaker in the Leapfrog My Own Leaptop.
필요한 것
Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
Once the cover is removed, gently lift up the speaker making sure not to rip or break the wires.
Gently turn the speaker over and carefully desolder the white and yellow wires from the speaker.
What do you do if the yellow wire is already broken off the silver part? How do you reapply it?
Erika Mata - 답글
Our white wire is halfway off, so I’m wondering if it can be soldered back on
Any issues that cannot be resolved with any portion of this wiki please contact Leapfrog Customer Serivce
다른 3명이 해당 안내서를 완성하였습니다.
댓글 5개
I agree, but I also second the question...where can I buy a replacement speaker?
Where could I buy the replacement speaker in Malaysia?
Where can I buy replacement speaker in Malaysia? Appreciate yr reply
ribenabona - 답글
