주요 콘텐츠로 건너뛰기
Lecia DME Light Source Bulb Replacement
필요한 것
  1. Lecia DME Light Source Bulb  Replacement, Light Source Bulb: 1 단계, 이미지 1/3 Lecia DME Light Source Bulb  Replacement, Light Source Bulb: 1 단계, 이미지 2/3 Lecia DME Light Source Bulb  Replacement, Light Source Bulb: 1 단계, 이미지 3/3
    • Set the Microscope up vertically.
    • Unplug the power cord from the microscope.
    • Do not pull from the wire. Hold it by the plug and pull away from the microscope.
  2. Lecia DME Light Source Bulb  Replacement: 2 단계, 이미지 1/2 Lecia DME Light Source Bulb  Replacement: 2 단계, 이미지 2/2
    • Carefully lay the microscope on its back to expose the bottom.
    • Hold it by the base and the frame in order to not to damage the microscope.
  3. Lecia DME Light Source Bulb  Replacement: 3 단계, 이미지 1/3 Lecia DME Light Source Bulb  Replacement: 3 단계, 이미지 2/3 Lecia DME Light Source Bulb  Replacement: 3 단계, 이미지 3/3
    • Pull the release knob away from the base to open the light hatch.
  4. Lecia DME Light Source Bulb  Replacement: 4 단계, 이미지 1/3 Lecia DME Light Source Bulb  Replacement: 4 단계, 이미지 2/3 Lecia DME Light Source Bulb  Replacement: 4 단계, 이미지 3/3
    • Carefully grab both sides of the light bulb.
    • Gently wiggle the light bulb side to side in order to remove it from the socket.
  5. Lecia DME Light Source Bulb  Replacement: 5 단계, 이미지 1/3 Lecia DME Light Source Bulb  Replacement: 5 단계, 이미지 2/3 Lecia DME Light Source Bulb  Replacement: 5 단계, 이미지 3/3
    • Grab a new 20W 12V halogen bulb to replace the broken one.
    • The place for the bulb information is located on the base of the microscope.
  6. Lecia DME Light Source Bulb  Replacement: 6 단계, 이미지 1/3 Lecia DME Light Source Bulb  Replacement: 6 단계, 이미지 2/3 Lecia DME Light Source Bulb  Replacement: 6 단계, 이미지 3/3
    • Take the new light bulb and firmly grasp the sides of it.
    • Insert the new bulb into the now empty socket.
    • Carefully wiggle it into place. Make sure its all the way in the socket to ensure a good connection.
  7. Lecia DME Light Source Bulb  Replacement: 7 단계, 이미지 1/2 Lecia DME Light Source Bulb  Replacement: 7 단계, 이미지 2/2
    • Close the hatch that covers the light bulb.
    • Push against the base until you hear the click of the pull and release knob setting back into place.
  8. Lecia DME Light Source Bulb  Replacement: 8 단계, 이미지 1/3 Lecia DME Light Source Bulb  Replacement: 8 단계, 이미지 2/3 Lecia DME Light Source Bulb  Replacement: 8 단계, 이미지 3/3
    • Hold the microscope by the base and frame and carefully place it upright.
    • Take the power cord and plug it back into the microscope.
  9. Lecia DME Light Source Bulb  Replacement: 9 단계, 이미지 1/1
    • Turn the red dial on the base of the microscope to test the new light.
결론
After replacing the old light your Leica Microscope should be up and working again.
Jackson Saulnier
회원 가입일: 02/04/20
169 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 30
전체 시간: 869
