주요 콘텐츠로 건너뛰기
Lego Dimensions Starter Pack USB Cable Replacement
필요한 것
  1. Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: 1 단계, 이미지 1/2 Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: 1 단계, 이미지 2/2
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
  2. Lego Dimensions Starter Pack USB Cable Replacement: 2 단계, 이미지 1/1
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
  3. Lego Dimensions Starter Pack USB Cable Replacement: 3 단계, 이미지 1/1
    • Pull the top cover off.
  4. Lego Dimensions Starter Pack USB Cable Replacement: 4 단계, 이미지 1/1
    • Lift up the circular illumination stand and remove it from the toy pad.
  5. Lego Dimensions Starter Pack USB Cable Replacement: 5 단계, 이미지 1/1
    • Lift up the white L-shaped pieces and remove them from the toy pad.
  6. Lego Dimensions Starter Pack USB Cable Replacement, USB Cable: 6 단계, 이미지 1/1
    • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
    • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
    • Remove the USB cable from the toy pad.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alyssa Lach
회원 가입일: 11/06/17
509 평판
안내서 4개 작성하였습니다
IUPUI, Team S5-G2, Baechle Fall 2017 IUPUI, Team S5-G2, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S5G2
2 회원들
안내서 8개 작성하였습니다
댓글 2개
Where do you buy the USB cable from?
jaimea371 - 답글
mguzmanv - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 13
30일 전: 48
전체 시간: 5,373
