주요 콘텐츠로 건너뛰기
Leica Z2X Flash Diffuser Replacement
필요한 것
  1. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Screws: 1 단계, 이미지 1개 중 1개
    • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
    • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
  2. Leica Z2X Flash Diffuser Replacement, Open the Back Door: 2 단계, 이미지 1개 중 1개
    • Open the back door on the camera by pushing down on the door latch.
  3. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Plate: 3 단계, 이미지 1개 중 1개
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
  4. Leica Z2X Flash Diffuser Replacement, Flash Diffuser: 4 단계, 이미지 1개 중 1개
    • Now that you've removed the bottom plate, you can pull apart the front and back covers.
    • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
  5. Leica Z2X Flash Diffuser Replacement: 5 단계, 이미지 1개 중 1개
    • Next, the back cover.
    • Apply pressure to remove the back plate.
    • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
    • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
  6. Leica Z2X Flash Diffuser Replacement: 6 단계, 이미지 1개 중 1개
    • You should now have removed the front and back plates.
  7. Leica Z2X Flash Diffuser Replacement: 7 단계, 이미지 1개 중 1개
    • Removing the flash diffuser should be simple from here.
    • Simply take the front cover and apply pressure to the front of the flash diffuser and it should pop right out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kenny
회원 가입일: 04/10/11
57 평판
안내서 3개를 작성함
Cal Poly, Team 18-19, Garner Spring 2011 Cal Poly, Team 18-19, Garner Spring 2011 회원
CPSU-GARNER-S11S18G19
4 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 18
전체 시간: 3,520
