주요 콘텐츠로 건너뛰기
Leica Z2X Lens Motor Replacement
필요한 것
  1. Leica Z2X Lens Motor Replacement, Remove the Bottom Screws: 1 단계, 이미지 1/1
    • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
    • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
  2. Leica Z2X Lens Motor Replacement, Open the Back Door: 2 단계, 이미지 1/1
    • Open the back door on the camera by pushing down on the door latch.
  3. Leica Z2X Lens Motor Replacement, Remove the Bottom Plate: 3 단계, 이미지 1/1
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
  4. Leica Z2X Lens Motor Replacement, Lens Motor: 4 단계, 이미지 1/1
    • Having opened the camera and removed the bottom plate, unscrew the five screws marked in the picture.
    • The screw marked in blue is a tiny bit harder to find because it's in a crevice. Don't miss it!
  5. Leica Z2X Lens Motor Replacement: 5 단계, 이미지 1/1
    • Apply pressure until the piece you unscrewed in the last step pops off.
  6. Leica Z2X Lens Motor Replacement: 6 단계, 이미지 1/1
    • Unscrew the four screws on the back of this piece to the lower-left corner of the lens.
  7. Leica Z2X Lens Motor Replacement: 7 단계, 이미지 1/1
    • Removing the lens motor cover, you should be left with these four pieces.
  8. Leica Z2X Lens Motor Replacement: 8 단계, 이미지 1/1
    • Located underneath these four pieces is the lens motor.
  9. Leica Z2X Lens Motor Replacement: 9 단계, 이미지 1/1
    • Now that you've removed the bottom plate, you can pull apart the front and back covers.
    • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
  10. Leica Z2X Lens Motor Replacement: 10 단계, 이미지 1/1
    • Next, the back cover.
    • Apply pressure to remove the back plate.
    • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
    • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
  11. Leica Z2X Lens Motor Replacement: 11 단계, 이미지 1/1
    • You should now have removed the front and back plates.
  12. Leica Z2X Lens Motor Replacement: 12 단계, 이미지 1/1
    • Remove the four screws holding on the front panel surrounding the lens.
  13. Leica Z2X Lens Motor Replacement: 13 단계, 이미지 1/1
    • Remove the three gears under the panel you removed in the last step and the lens motor should be able to be removed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Zachary
회원 가입일: 04/12/11
46 평판
안내서 2개 작성하였습니다
Cal Poly, Team 18-19, Garner Spring 2011 Cal Poly, Team 18-19, Garner Spring 2011 회원
CPSU-GARNER-S11S18G19
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 2,614
