주요 콘텐츠로 건너뛰기
Lenovo 100e Chromebook 2nd Gen Battery Replacement
필요한 것
  1. Lenovo 100e Chromebook 2nd Gen Battery Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Battery Replacement: 2 단계, 이미지 1/2 Lenovo 100e Chromebook 2nd Gen Battery Replacement: 2 단계, 이미지 2/2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Battery Replacement: 3 단계, 이미지 1/2 Lenovo 100e Chromebook 2nd Gen Battery Replacement: 3 단계, 이미지 2/2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Battery Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the four 4 mm Phillips #0 screws holding the battery in.
  5. Lenovo 100e Chromebook 2nd Gen Battery Replacement: 5 단계, 이미지 1/1
    • Using an opening pick, push on the connection where the wires are connected to the motherboard.
    • Potential for device damage: This step takes some force to disconnect, but be careful to not pull the wires out of the battery.
  6. Lenovo 100e Chromebook 2nd Gen Battery Replacement: 6 단계, 이미지 1/1
    • The battery is now loose and can be removed from the laptop.
결론
Pup Washington
회원 가입일: 01/14/21
582 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 22
30일 전: 87
전체 시간: 2,211
