주요 콘텐츠로 건너뛰기
Lenovo 100e Chromebook 2nd Gen Camera Replacement
필요한 것
  1. Lenovo 100e Chromebook 2nd Gen Camera Replacement, Screen Bezel: 1 단계, 이미지 1/1
    • Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
  2. Lenovo 100e Chromebook 2nd Gen Camera Replacement: 2 단계, 이미지 1/1
    • Insert the spudger into the gap between the hinges and pull up to detach the connections.
  3. Lenovo 100e Chromebook 2nd Gen Camera Replacement: 3 단계, 이미지 1/1
    • Remove the screen bezel from the laptop.
  4. Lenovo 100e Chromebook 2nd Gen Camera Replacement, Camera: 4 단계, 이미지 1/1
    • Using the opening pick, pry the camera from the front of the laptop.
  5. Lenovo 100e Chromebook 2nd Gen Camera Replacement: 5 단계, 이미지 1/1
    • Carefully pinch and pull on the connection between the camera and the motherboard.
    • The camera is now loose and can be removed.
결론
Chester Wallace
회원 가입일: 01/14/21
259 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 531
