주요 콘텐츠로 건너뛰기
Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement
필요한 것
  1. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: 2 단계, 이미지 2개 중 1개 Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: 2 단계, 이미지 2개 중 2개
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: 3 단계, 이미지 2개 중 1개 Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement, Headphone Jack: 4 단계, 이미지 1개 중 1개
    • Remove the three 4 mm Phillips #0 screws holding the headphone jack in place.
  5. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: 5 단계, 이미지 1개 중 1개
    • Using a plastic opening pick, remove the connection between the aux port and the speakers.
  6. Lenovo 100e Chromebook 2nd Gen Headphone Jack Replacement: 6 단계, 이미지 1개 중 1개
    • Using the plastic opening pick, pop the retaining flap holding the ribbon cable in place.
    • Remove the headphone jack from the laptop.
결론
작성자
5다른 기여자 명과 함께
Pup Washington
회원 가입일: 01/14/21
585 평판
안내서 6개를 작성함
1가이드 댓글
I believe our model has the headphone jack soldered on. Any other ideas?
L Hart - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 29
전체 시간: 1,428
