주요 콘텐츠로 건너뛰기
Lenovo 100e Chromebook 2nd Gen Hinges Replacement
필요한 것
  1. Lenovo 100e Chromebook 2nd Gen Hinges Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 2 단계, 이미지 1/2 Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 2 단계, 이미지 2/2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 3 단계, 이미지 1/2 Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 3 단계, 이미지 2/2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Hinges Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the four 4 mm Phillips #0 screws holding the battery in.
  5. Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 5 단계, 이미지 1/1
    • Using an opening pick, push on the connection where the wires are connected to the motherboard.
    • Potential for device damage: This step takes some force to disconnect, but be careful to not pull the wires out of the battery.
  6. Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 6 단계, 이미지 1/1
    • The battery is now loose and can be removed from the laptop.
  7. Lenovo 100e Chromebook 2nd Gen Hinges Replacement, Screen Bezel: 7 단계, 이미지 1/1
    • Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
  8. Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 8 단계, 이미지 1/1
    • Insert the spudger into the gap between the hinges and pull up to detach the connections.
  9. Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 9 단계, 이미지 1/1
    • Remove the screen bezel from the laptop.
  10. Lenovo 100e Chromebook 2nd Gen Hinges Replacement, Display: 10 단계, 이미지 1/1
    • Remove the four 3.4 mm screws holding the screen in place using the Phillips #00 screwdriver.
  11. Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 11 단계, 이미지 1/1
    • Carefully pull the screen back onto the lower assembly.
  12. Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 12 단계, 이미지 1/3 Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 12 단계, 이미지 2/3 Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 12 단계, 이미지 3/3
    • Peel back the protective tape over the display cable using the spudger.
    • Gently lift the black bar latch holding the cable in place, until the cable becomes loose.
    • Pull the cable free and remove the display.
    • DO NOT pull on the cable before lifting the bar latch or the cable will break.
  13. Lenovo 100e Chromebook 2nd Gen Hinges Replacement, Hinges: 13 단계, 이미지 1/3 Lenovo 100e Chromebook 2nd Gen Hinges Replacement, Hinges: 13 단계, 이미지 2/3 Lenovo 100e Chromebook 2nd Gen Hinges Replacement, Hinges: 13 단계, 이미지 3/3
    • Use the Phillips #0 screwdriver to remove the six 4.7 mm screws located on the bottom half of each hinge.
    • Use the Phillips #00 screwdriver to remove the ten 3.4 mm screws located on the upper hinge assembly.
  14. Lenovo 100e Chromebook 2nd Gen Hinges Replacement: 14 단계, 이미지 1/1
    • Move the screen assembly perpendicular to the keyboard assembly.
    • Remove the hinges by pulling straight up.
결론
Charles Blaine Geiger
회원 가입일: 09/21/21
190 평판
안내서 2개 작성하였습니다
댓글 한 개
Any Ideas on how to repair popped rivets from the hinges? I've tried epoxy without much luck, but I've got hinges popped at the top and bottom of the display.
Donald Johnson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 25
30일 전: 77
전체 시간: 1,154
