주요 콘텐츠로 건너뛰기
Lenovo 100e Chromebook 2nd Gen Trackpad Replacement
필요한 것
  1. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove the nine 6 mm screws from the back of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: 2 단계, 이미지 1/2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: 2 단계, 이미지 2/2
    • Open the laptop and lay it flat.
    • Go along the edge of the keyboard with an opening tool until it pops loose.
    • Potential for device damage: Make sure that the keyboard does not fall away from the laptop, as it is still connected to the internal components
  3. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: 3 단계, 이미지 1/2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: 3 단계, 이미지 2/2
    • Lift the keyboard connectors up using an opening pick.
    • Remove the connectors from their sockets.
  4. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement, Trackpad: 4 단계, 이미지 1/1
    • Remove the three 2 mm Phillips #00 screws holding the trackpad in.
  5. Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: 5 단계, 이미지 1/2 Lenovo 100e Chromebook 2nd Gen Trackpad Replacement: 5 단계, 이미지 2/2
    • Push up on the side of the trackpad that faces the screen.
    • Pop the trackpad out and remove it from the laptop.
결론
Pup Washington
회원 가입일: 01/14/21
582 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 1,117
