주요 콘텐츠로 건너뛰기
Lenovo 100s Chromebook-11IBY Speaker Replacement
필요한 것
  1. Lenovo 100s Chromebook-11IBY Speaker Replacement, Speakers: 1 단계, 이미지 1개 중 1개
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Use a #0 Phillips screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Speaker Replacement: 3 단계, 이미지 2개 중 1개 Lenovo 100s Chromebook-11IBY Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Speaker Replacement: 4 단계, 이미지 3개 중 1개 Lenovo 100s Chromebook-11IBY Speaker Replacement: 4 단계, 이미지 3개 중 2개 Lenovo 100s Chromebook-11IBY Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Locate the two sticker-like connecting wires (for the keyboard and touchpad).
    • Carefully unplug the orange circled (keyboard) wire from the keyboard plate.
    • Carefully unplug the yellow circled (touchpad) wire from the keyboard plate.
    • Then lift the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Locate the cable attaching the left speaker to the motherboard and unplug it by hand.
    • Then unplug the cable attaching the right speaker by hand.
  6. Lenovo 100s Chromebook-11IBY Speaker Replacement: 6 단계, 이미지 2개 중 1개 Lenovo 100s Chromebook-11IBY Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully pry the speaker up and free of the two notches holding it in place.
    • Remove the speaker.
  7. Lenovo 100s Chromebook-11IBY Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Repeat steps 5 & 6 in order to remove the right speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Milton Perez
회원 가입일: 03/09/17
630 평판
안내서 5개를 작성함
USF Tampa, Team S7-G2, Cagle Spring 2017 USF Tampa, Team S7-G2, Cagle Spring 2017 회원
USFT-CAGLE-S17S7G2
1 회원
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 648
