주요 콘텐츠로 건너뛰기
Lenovo 100s Chromebook-11IBY Webcam Replacement
필요한 것
  1. Lenovo 100s Chromebook-11IBY Webcam Replacement, Webcam: 1 단계, 이미지 1/1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Webcam Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Lenovo 100s Chromebook-11IBY Webcam Replacement: 3 단계, 이미지 1/2 Lenovo 100s Chromebook-11IBY Webcam Replacement: 3 단계, 이미지 2/2
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Lenovo 100s Chromebook-11IBY Webcam Replacement: 4 단계, 이미지 1/2 Lenovo 100s Chromebook-11IBY Webcam Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Lenovo 100s Chromebook-11IBY Webcam Replacement: 5 단계, 이미지 1/1
    • Gently unplug the wire connecting the webcam to the laptop.
  6. Lenovo 100s Chromebook-11IBY Webcam Replacement: 6 단계, 이미지 1/2 Lenovo 100s Chromebook-11IBY Webcam Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool, gently lift the webcam panel from the screen. Then remove it.
결론
Milton Perez
회원 가입일: 03/09/17
630 평판
안내서 5개 작성하였습니다
USF Tampa, Team S7-G2, Cagle Spring 2017 USF Tampa, Team S7-G2, Cagle Spring 2017 회원
USFT-CAGLE-S17S7G2
1 회원
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 344
