소개
This guide shows how to remove the battery, WiFi card, keyboard, and Write-Protect screw on a Lenovo 11e ThinkPad Chromebook.
Unplug the Battery
Unscrew battery and remove
Remove all all circled screws
I removed the wireless card. I don't know if it's required.
Slide Keyboard up
Wedge something under the keyboard
flip the keyboard over
carefully remove the keyboard ribbon cable
Unscrew and disconnect ribbon cables
wedge something between the bezel and slide across the edge until the bezel is lifted (like taking off a bike tire)
The write-protect screw is clearly conducting electricity (compare it to other screws on the board).
Leave the WP screw out of the laptop.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Le système software this chromebook
This chromebook runs ChromeOS. Removing the write-protect screw and running MrChromeBox's Firmware Utility Script allows any linux distribution to run on this chromebook.
