주요 콘텐츠로 건너뛰기
Lenovo 300e Windows 2nd Gen Battery Replacement
필요한 것
  1. Lenovo 300e Windows 2nd Gen Battery Replacement, Remove the back: 1 단계, 이미지 3개 중 1개 Lenovo 300e Windows 2nd Gen Battery Replacement, Remove the back: 1 단계, 이미지 3개 중 2개 Lenovo 300e Windows 2nd Gen Battery Replacement, Remove the back: 1 단계, 이미지 3개 중 3개
    • Use a screwdriver to remove all 9 screws at the bottom of the laptop.
    • Take off the panel and set it aside.
    • Some screws may not lift out of the casing. If this happens, just loosen every screw and lift the entire back off of the device.
    • The first image highlighting the screws was too big to fit. Some parts were cropped out.
  2. Lenovo 300e Windows 2nd Gen Battery Replacement, Unscrew the battery: 2 단계, 이미지 1개 중 1개
    • Unscrew all four screws holding the battery in place. Set them aside.
    • Be sure to not puncture the battery. It may explode or catch fire if it is mistreated. Proceed with caution. Especially if your battery is puffy!
  3. Lenovo 300e Windows 2nd Gen Battery Replacement, Unplug the battery.: 3 단계, 이미지 2개 중 1개 Lenovo 300e Windows 2nd Gen Battery Replacement, Unplug the battery.: 3 단계, 이미지 2개 중 2개
    • Carefully unplug the battery from the device.
  4. Lenovo 300e Windows 2nd Gen Battery Replacement, Remove the battery.: 4 단계, 이미지 2개 중 1개 Lenovo 300e Windows 2nd Gen Battery Replacement, Remove the battery.: 4 단계, 이미지 2개 중 2개
    • Carefully slide the batter toward you (Away from the motherboard, imagine you are in the perspective of the image)
    • Do not lift the battery directly. You might harm the wire going over the battery. Make sure you slide it out from under the wire before you completely remove it from the housing.
결론
Put the battery back in the same way you took it out: carefully slide it into place. Don't shove the battery wire into place; be gentle.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kyeler W
회원 가입일: 03/04/25
670 평판
안내서 8개를 작성함
Android Alliance Android Alliance 회원
Community
92 회원들
안내서 735개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 25
전체 시간: 25
