주요 콘텐츠로 건너뛰기
Lenovo A7-40, A7-50 A3500 Factory Reset
필요한 것
동영상 개요
  1. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: 1 단계, 이미지 1/3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: 1 단계, 이미지 2/3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: 1 단계, 이미지 3/3
    • 1. Switch of the tablet. If the device freezes, you can use a reset hole under the memory card reader cover.
    • 2. Press and hod: Volume Up + Volume Down + Power buttons.
    • 3. In the Recovery menu, use the Volume Down button to move the highlight and the Volume Up to select.
    • 4. Choose one by one: "wipe data/factory reset", "Yes -- delete all user data" and finally "reboot system now".
  2. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: 2 단계, 이미지 1/3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: 2 단계, 이미지 2/3 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: 2 단계, 이미지 3/3
    • 1. Switch off the tablet.
    • 2. Press and hold the Volume Up and Power On keys.
    • 3. When you feel release only the Power button. Now your device is in Factory mode.
    • 4. Use the Volume Up/Down keys for movement and the Power key for select.
    • 5. Select ¶§ eMMC (Clean eMMC)
    • Did you do it successfully?
결론
다른 33명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
192,056 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,525개 작성하였습니다
댓글 17개
let me try and see
usman aleeyu - 답글
Is it applicable to my lenovo a516?
valvinzon - 답글
yes it works thanks
abdullahjanajy - 답글
Love you so much goodnight baby
Van Prince -
Well thanks!! I was worried about my tab and now i can fix easily tab without paying others to fix my tab. Thank you again :))
Christian Lemuel Espenilla - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 27
30일 전: 93
전체 시간: 106,455
