주요 콘텐츠로 건너뛰기
Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement
필요한 것
동영상 개요
  1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Switch off the laptop, disconnect the AC adapter, and remove the battery.
  2. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: 2 단계, 이미지 1/2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: 2 단계, 이미지 2/2
    • Remove the screws securing the Memory / HDD cover.
    • Slide the cover down and remove it.
  3. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: 3 단계, 이미지 1/2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: 3 단계, 이미지 2/2
    • To pop up the memory module you’ll have to spread latches on both sides of the slot.
    • MEMORY
    • Speed 1600 MHz / PC3L-12800
    • Technology DDR3L SDRAM SODIMM
    • Max Supported Size 16 GB
    • Form Factor SO-DIMM 204-pin
    • Slots Qty 2
    • Empty Slots 1
  4. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): 4 단계, 이미지 1/3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): 4 단계, 이미지 2/3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): 4 단계, 이미지 3/3
    • Remove two screws securing the hard drive mounting bracked.
    • Slide the HDD to the left to disconnect it from the motherboard and remove it from the device.
    • Remove two screws on each side of the HDD to remove the mounting bracket.
    • Now you have to transfer the mounting bracket to the new HDD or SSD.
  5. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: 5 단계, 이미지 1/2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: 5 단계, 이미지 2/2
    • Remove the screw and disconnect the two coaxial antenna cables from the WiFi card.
    • Pop it up and remove it from the slot.
    • Wireless N M.2, or Next Generation Form Factor (NGFF) Card.
  6. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: 6 단계, 이미지 1/3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: 6 단계, 이미지 2/3 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: 6 단계, 이미지 3/3
    • Complementary Metal-Oxide-Semiconductor (CMOS) aka Real-Time Clock (RTC)
    • CR2032
  7. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement: 7 단계, 이미지 1/1
    • That's all.
결론
다른 3명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,341 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,541개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 62
전체 시간: 7,274
