주요 콘텐츠로 건너뛰기
Lenovo B575-1450 CD-ROM Drive Replacement
필요한 것
  1. Lenovo B575-1450 CD-ROM Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 CD-ROM Drive Replacement: 2 단계, 이미지 1/2 Lenovo B575-1450 CD-ROM Drive Replacement: 2 단계, 이미지 2/2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 CD-ROM Drive Replacement: 3 단계, 이미지 1/3 Lenovo B575-1450 CD-ROM Drive Replacement: 3 단계, 이미지 2/3 Lenovo B575-1450 CD-ROM Drive Replacement: 3 단계, 이미지 3/3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 CD-ROM Drive Replacement, Back Panel: 4 단계, 이미지 1/2 Lenovo B575-1450 CD-ROM Drive Replacement, Back Panel: 4 단계, 이미지 2/2
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 CD-ROM Drive Replacement: 5 단계, 이미지 1/1
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 CD-ROM Drive Replacement: 6 단계, 이미지 1/1
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
  7. Lenovo B575-1450 CD-ROM Drive Replacement, CD-ROM Drive: 7 단계, 이미지 1/2 Lenovo B575-1450 CD-ROM Drive Replacement, CD-ROM Drive: 7 단계, 이미지 2/2
    • Using the Phillips #00 Screwdriver, remove the 3.4 mm screw from the CD-ROM bracket.
    • This unlocks the CD-ROM drive from the computer
  8. Lenovo B575-1450 CD-ROM Drive Replacement: 8 단계, 이미지 1/2 Lenovo B575-1450 CD-ROM Drive Replacement: 8 단계, 이미지 2/2
    • Pry CD-ROM drive from laptop using a plastic opening tool.
    • Pull the CD-ROM drive the rest of the way out.
결론
Carlo Calvillo
회원 가입일: 09/26/16
772 평판
안내서 6개 작성하였습니다
댓글 한 개
Can u please show me how to assemble or fix dvd drive lock mechanism for lenovo e49.
nukuvsh4 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 496
