주요 콘텐츠로 건너뛰기
Lenovo B575-1450 Display Panel Replacement
필요한 것
  1. Lenovo B575-1450 Display Panel  Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 Display Panel  Replacement: 2 단계, 이미지 1/2 Lenovo B575-1450 Display Panel  Replacement: 2 단계, 이미지 2/2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 Display Panel  Replacement: 3 단계, 이미지 1/3 Lenovo B575-1450 Display Panel  Replacement: 3 단계, 이미지 2/3 Lenovo B575-1450 Display Panel  Replacement: 3 단계, 이미지 3/3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 Display Panel  Replacement, Display Panel: 4 단계, 이미지 1/2 Lenovo B575-1450 Display Panel  Replacement, Display Panel: 4 단계, 이미지 2/2
    • Remove both screw covers from the bottom of screen bezel using a plastic spudger. The screws underneath will now be exposed
  5. Lenovo B575-1450 Display Panel  Replacement: 5 단계, 이미지 1/1
    • Using the Phillips #0 Screwdriver, remove the two 4.3 mm screws holding the display to the front bezel.
  6. Lenovo B575-1450 Display Panel  Replacement: 6 단계, 이미지 1/2 Lenovo B575-1450 Display Panel  Replacement: 6 단계, 이미지 2/2
    • Separate the front bezel from the display panel using the plastic opening tool by gently prying around the edges and removing it.
  7. Lenovo B575-1450 Display Panel  Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the tweezers carefully disconnect the ZIF connector by pulling cable away from front facing camera that is attached to the back bezel.
  8. Lenovo B575-1450 Display Panel  Replacement: 8 단계, 이미지 1/3 Lenovo B575-1450 Display Panel  Replacement: 8 단계, 이미지 2/3 Lenovo B575-1450 Display Panel  Replacement: 8 단계, 이미지 3/3
    • Using the Phillips #0 Screwdriver, remove the six 4.3 mm screws that connect display screen to the rear bezel.
    • There are two screws in the bottom left and right corners of the frame.
  9. Lenovo B575-1450 Display Panel  Replacement: 9 단계, 이미지 1/2 Lenovo B575-1450 Display Panel  Replacement: 9 단계, 이미지 2/2
    • Using the Phillips #0 Screwdriver, remove the four 2.9 mm screws from each side of the bracket that holds the display panel in place.
  10. Lenovo B575-1450 Display Panel  Replacement: 10 단계, 이미지 1/2 Lenovo B575-1450 Display Panel  Replacement: 10 단계, 이미지 2/2
    • Lay display panel face down on the keyboard.
    • Peel back the flat wire that has the camera's ZIF connector until it is loose from the back of the display.
    • Carefully peel of the clear adhesive tape attached to the primary display ZIF connector using a plastic spudger.
  11. Lenovo B575-1450 Display Panel  Replacement: 11 단계, 이미지 1/2 Lenovo B575-1450 Display Panel  Replacement: 11 단계, 이미지 2/2
    • Place the metal tweezer tips between the ZIF connector and the wire-to-board connection.
    • Carefully separate ZIF wire-to-board connection by pulling metal tweezers in a downward motion.
    • Pull up on flat wire until display is completely disconnected.
    • Be very careful when separating ZIF connections . The ends of the ZIF wire connectors are delicate and can break easily.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Carlo Calvillo
회원 가입일: 09/26/16
772 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 1,423
