주요 콘텐츠로 건너뛰기
Lenovo B575-1450 RAM Replacement
필요한 것
  1. Lenovo B575-1450 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Lenovo B575-1450 RAM Replacement: 2 단계, 이미지 1/2 Lenovo B575-1450 RAM Replacement: 2 단계, 이미지 2/2
    • Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo B575-1450 RAM Replacement: 3 단계, 이미지 1/3 Lenovo B575-1450 RAM Replacement: 3 단계, 이미지 2/3 Lenovo B575-1450 RAM Replacement: 3 단계, 이미지 3/3
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. Lenovo B575-1450 RAM Replacement, Back Panel: 4 단계, 이미지 1/2 Lenovo B575-1450 RAM Replacement, Back Panel: 4 단계, 이미지 2/2
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Lenovo B575-1450 RAM Replacement: 5 단계, 이미지 1/1
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Lenovo B575-1450 RAM Replacement: 6 단계, 이미지 1/1
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
  7. Lenovo B575-1450 RAM Replacement, RAM: 7 단계, 이미지 1/2 Lenovo B575-1450 RAM Replacement, RAM: 7 단계, 이미지 2/2
    • Using a plastic opening tool, pry the RAM upwards until the card pops out of the brackets.
    • Pull the RAM out from the slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Carlo Calvillo
회원 가입일: 09/26/16
772 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 1,257
