소개
A failing Wi-Fi card can be disastrous to a computers operations. It can prevent the laptop from accessing wireless resources and potentially cutting it off from the Internet. Removing and replacing the Wi-Fi card for this laptop is quick and easy.
필요한 것
Turn off the computer.
Disconnect the charger from the computer.
Flip the computer upside down.
Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
Using the plastic opening tool, detach both black and grey cables from the Wi-Fi card.
다른 한 분이 해당 안내서를 완성하였습니다.
