주요 콘텐츠로 건너뛰기
Lenovo Edge 15 Hard Drive Disk Replacement
필요한 것
  1. Lenovo Edge 15 Hard Drive Disk Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo Edge 15 Hard Drive Disk Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Locate the eleven M2 x 6.0mm back-cover screws.
    • Unscrew the screws using the Phillips #0 screwdriver.
    • If battery is leaking, do not touch with bare hands.
  2. Lenovo Edge 15 Hard Drive Disk Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Edge 15 Hard Drive Disk Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift the cover plate off the body of the laptop, ensuring that it does not pull on any components such as the USB ports.
  3. Lenovo Edge 15 Hard Drive Disk Replacement: 3 단계, 이미지 3개 중 1개 Lenovo Edge 15 Hard Drive Disk Replacement: 3 단계, 이미지 3개 중 2개 Lenovo Edge 15 Hard Drive Disk Replacement: 3 단계, 이미지 3개 중 3개
    • Locate the battery-connector and the three, M2 x 4.0mm screws holding the battery in place.
    • Carefully unplug the battery-connector, wiggling the connector side to side if needed.
    • Unscrew the 3-screws using the Phillips # 0 screwdriver.
  4. Lenovo Edge 15 Hard Drive Disk Replacement: 4 단계, 이미지 2개 중 1개 Lenovo Edge 15 Hard Drive Disk Replacement: 4 단계, 이미지 2개 중 2개
    • Gently lift all four corners of the battery to remove it from the laptop.
  5. Lenovo Edge 15 Hard Drive Disk Replacement, Hard Drive Disk: 5 단계, 이미지 2개 중 1개 Lenovo Edge 15 Hard Drive Disk Replacement, Hard Drive Disk: 5 단계, 이미지 2개 중 2개
    • Set the battery aside. This will allow easier access to the connector for the HDD.
    • Keep the batches of screws from the battery, HDD, case and cover plate separate. Although the screws may look similar, they have slightly different lengths and thread pitches for the different components.
  6. Lenovo Edge 15 Hard Drive Disk Replacement: 6 단계, 이미지 2개 중 1개 Lenovo Edge 15 Hard Drive Disk Replacement: 6 단계, 이미지 2개 중 2개
    • The right side speaker can be lifted up off of its mounts and set out of the way if desired, but don't put sharp bends in the speaker wires.
  7. Lenovo Edge 15 Hard Drive Disk Replacement: 7 단계, 이미지 1개 중 1개
    • With the Phillips #0 screwdriver, remove the 4 M2 x 4.0mm screws holding the HDD case to the laptop body.
  8. Lenovo Edge 15 Hard Drive Disk Replacement: 8 단계, 이미지 2개 중 1개 Lenovo Edge 15 Hard Drive Disk Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the HDD case up, and gently pull at the sides of the connector to disconnect it.
  9. Lenovo Edge 15 Hard Drive Disk Replacement: 9 단계, 이미지 3개 중 1개 Lenovo Edge 15 Hard Drive Disk Replacement: 9 단계, 이미지 3개 중 2개 Lenovo Edge 15 Hard Drive Disk Replacement: 9 단계, 이미지 3개 중 3개
    • With the Phillips #1, remove the 4 M3 x 4.0mm screws on the sides of the case.
    • The hard drive can now be removed.
결론
During assembly, take careful note of the following items:
1) Keep track of the correct screws for each application.
2) Components may need to be wiggled to allow for proper screw alignment.
3) Don’t force screws in to avoid cross-threading.
4) Ensure proper connector alignment when reconnecting the HDD and battery cables.
Again, here is a video to help install a Windows OS on your new HDD: https://www.youtube.com/watch?v=tjmRWFep...
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
David Daley
회원 가입일: 09/27/17
239 평판
안내서 1개를 작성함
Cal Poly, Team S8-G1, Banghart Fall 2017 Cal Poly, Team S8-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G1
5 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 65
전체 시간: 6,247
