주요 콘텐츠로 건너뛰기
Lenovo Edge 15 Wireless LAN Card Replacement
필요한 것
  1. Lenovo Edge 15 Wireless LAN Card Replacement, Wireless LAN Card: 1 단계, 이미지 1/1
    • With the laptop upside-down, remove all 11 M2 x 6.0mm screws from the cover plate using the Phillips #0 screwdriver.
  2. Lenovo Edge 15 Wireless LAN Card Replacement: 2 단계, 이미지 1/1
    • Gently lift the cover plate off the body of the laptop, ensuring that it does not pull on any components such as the USB ports.
  3. Lenovo Edge 15 Wireless LAN Card Replacement: 3 단계, 이미지 1/1
    • Remove single 3mm screw holding down the end of the card using a Phillips #1 screwdriver.
  4. Lenovo Edge 15 Wireless LAN Card Replacement: 4 단계, 이미지 1/2 Lenovo Edge 15 Wireless LAN Card Replacement: 4 단계, 이미지 2/2
    • Use hands to disconnect card from slot and remove both cables.
    • When replacing connectors be sure to reconnect to proper terminal. Do this by orienting as is in the picture and attaching black cable to left side and white cable to right side.
결론
To reassemble your device, follow these instructions in reverse order. Make sure that connectors are in proper position as shown in step 3.
다른 2명이 해당 안내서를 완성하였습니다.
ryan sanders
회원 가입일: 09/27/17
350 평판
안내서 2개 작성하였습니다
Cal Poly, Team S8-G1, Banghart Fall 2017 Cal Poly, Team S8-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G1
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 1,550
