주요 콘텐츠로 건너뛰기
Lenovo Edge 2-1580 Motherboard Replacement
필요한 것
  1. Lenovo Edge 2-1580 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Motherboard Replacement: 2 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 2 단계, 이미지 2/2
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Motherboard Replacement: 3 단계, 이미지 1/3 Lenovo Edge 2-1580 Motherboard Replacement: 3 단계, 이미지 2/3 Lenovo Edge 2-1580 Motherboard Replacement: 3 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Motherboard Replacement: 4 단계, 이미지 1/1
    • Pull the battery outward and remove it from the rest of the laptop.
  5. Lenovo Edge 2-1580 Motherboard Replacement, Hard drive: 5 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement, Hard drive: 5 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
  6. Lenovo Edge 2-1580 Motherboard Replacement: 6 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 6 단계, 이미지 2/2
    • Slide the drive away from the connector by applying pressure on the two side tabs where screws were removed. Use a plastic opening tool as a lever to lift the drive out.
  7. Lenovo Edge 2-1580 Motherboard Replacement: 7 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 7 단계, 이미지 2/2
    • Carefully, using your hand, remove the hard drive from the laptop.
  8. Lenovo Edge 2-1580 Motherboard Replacement, Fan: 8 단계, 이미지 1/3 Lenovo Edge 2-1580 Motherboard Replacement, Fan: 8 단계, 이미지 2/3 Lenovo Edge 2-1580 Motherboard Replacement, Fan: 8 단계, 이미지 3/3
    • Remove the 5.4 mm Phillips #0 screw holding the Wireless Network Card.
    • The network card will pop up by itself.
  9. Lenovo Edge 2-1580 Motherboard Replacement: 9 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 9 단계, 이미지 2/2
    • Grab the network card and gently pull it out.
  10. Lenovo Edge 2-1580 Motherboard Replacement: 10 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 10 단계, 이미지 2/2
    • Pull out the RAM metallic cover.
  11. Lenovo Edge 2-1580 Motherboard Replacement: 11 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 11 단계, 이미지 2/2
    • Grab the black insulating tape and pull it out.
  12. Lenovo Edge 2-1580 Motherboard Replacement: 12 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 12 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the (6) six fan screws from the device.
    • (5) Five copper and (1) one silver Phillips #0 5.4mm screws.
    • Disconnect the fan from the motherboard.
  13. Lenovo Edge 2-1580 Motherboard Replacement: 13 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 13 단계, 이미지 2/2
    • Unplug the Fan connector from its socket on the motherboard.
  14. Lenovo Edge 2-1580 Motherboard Replacement: 14 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 14 단계, 이미지 2/2
    • Carefully remove the fan from the laptop.
  15. Lenovo Edge 2-1580 Motherboard Replacement, Motherboard: 15 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement, Motherboard: 15 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the (2) two 5.4 mm Phillips screws.
    • Disconnect these connectors from the motherboard.
    • Disconnect the four ribbon cables from the motherboard.
    • Unscrew and remove the (2) two Phillips #0 screws.
  16. Lenovo Edge 2-1580 Motherboard Replacement: 16 단계, 이미지 1/3 Lenovo Edge 2-1580 Motherboard Replacement: 16 단계, 이미지 2/3 Lenovo Edge 2-1580 Motherboard Replacement: 16 단계, 이미지 3/3
    • Lift up the black latch of the ribbon cable with the brown tab on top by holding the cable in to the motherboard.
    • Grab the tab with a pair of pliers and pull out the cable.
  17. Lenovo Edge 2-1580 Motherboard Replacement: 17 단계, 이미지 1/3 Lenovo Edge 2-1580 Motherboard Replacement: 17 단계, 이미지 2/3 Lenovo Edge 2-1580 Motherboard Replacement: 17 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Lift the beige latch of the ribbon cable with the blue tab by holding the cable in to the motherboard, and with a pair of tweezers, pull out the cable.
  18. Lenovo Edge 2-1580 Motherboard Replacement: 18 단계, 이미지 1/3 Lenovo Edge 2-1580 Motherboard Replacement: 18 단계, 이미지 2/3 Lenovo Edge 2-1580 Motherboard Replacement: 18 단계, 이미지 3/3
    • Lift up the black latch of the ribbon cable with the blue tab at the lower right corner of the motherboard and disconnect it with a pair of tweezers.
    • Grab the tab and pull out the cable.
  19. Lenovo Edge 2-1580 Motherboard Replacement: 19 단계, 이미지 1/3 Lenovo Edge 2-1580 Motherboard Replacement: 19 단계, 이미지 2/3 Lenovo Edge 2-1580 Motherboard Replacement: 19 단계, 이미지 3/3
    • Locate the last ribbon cable with a blue tab and lift the beige latch holding the cable in to the motherboard.
    • With a pair of tweezers grab the tab and remove the cable.
  20. Lenovo Edge 2-1580 Motherboard Replacement: 20 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 20 단계, 이미지 2/2
    • Lift the black latch of the black connector at the top left corner of the motherboard by holding it in to the motherboard.
    • Grab the cable and pull it outwards to remove it.
  21. Lenovo Edge 2-1580 Motherboard Replacement: 21 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 21 단계, 이미지 2/2
    • Pull the wire besides the brown tab ribbon cable out and disconnect it.
  22. Lenovo Edge 2-1580 Motherboard Replacement: 22 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 22 단계, 이미지 2/2
    • Grab the small black connector by the RAM module and disconnect it from the motherboard.
  23. Lenovo Edge 2-1580 Motherboard Replacement: 23 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 23 단계, 이미지 2/2
    • Unplug the remaining connector besides the RAM module and remove it from the motherboard.
  24. Lenovo Edge 2-1580 Motherboard Replacement: 24 단계, 이미지 1/2 Lenovo Edge 2-1580 Motherboard Replacement: 24 단계, 이미지 2/2
    • Gently grab the motherboard and pull it up lightly. Then pull it towards you and remove the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Julian Escallon
회원 가입일: 09/27/17
714 평판
안내서 5개 작성하였습니다
USF Tampa, Team S14-G1, Boczar Fall 2017 USF Tampa, Team S14-G1, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 8
30일 전: 25
전체 시간: 2,154
