소개
The guide will show you how to remove and replace the RAM module that comes with the laptop. Be sure the new replacement module is compatible with the motherboard.
필요한 것
Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
Pull the battery outward and remove it from the rest of the laptop.
The removal of the hard drive isn’t completely necessary in order to access the hard drive for removal.
거의 끝나갑니다!
결론
댓글 2개
but how exactly do i open the cover?
