주요 콘텐츠로 건너뛰기
Lenovo Edge 2-1580 Storage Replacement
필요한 것
  1. Lenovo Edge 2-1580 Storage Replacement, Battery: 1 단계, 이미지 1/2 Lenovo Edge 2-1580 Storage Replacement, Battery: 1 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the (11) eleven 5.4 mm screws from the back panel.
  2. Lenovo Edge 2-1580 Storage Replacement: 2 단계, 이미지 1/2 Lenovo Edge 2-1580 Storage Replacement: 2 단계, 이미지 2/2
    • Using a plastic opening tool, pull out the back panel from the laptop.
  3. Lenovo Edge 2-1580 Storage Replacement: 3 단계, 이미지 1/3 Lenovo Edge 2-1580 Storage Replacement: 3 단계, 이미지 2/3 Lenovo Edge 2-1580 Storage Replacement: 3 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the (2) 5.4 mm screws.
    • Disconnect the battery connector from the motherboard.
  4. Lenovo Edge 2-1580 Storage Replacement: 4 단계, 이미지 1/1
    • Pull the battery outward and remove it from the rest of the laptop.
  5. Lenovo Edge 2-1580 Storage Replacement, Hard drive: 5 단계, 이미지 1/2 Lenovo Edge 2-1580 Storage Replacement, Hard drive: 5 단계, 이미지 2/2
    • Using the Phillips #0 screwdriver, remove the (3) three 3 mm screws.
  6. Lenovo Edge 2-1580 Storage Replacement: 6 단계, 이미지 1/2 Lenovo Edge 2-1580 Storage Replacement: 6 단계, 이미지 2/2
    • Slide the drive away from the connector by applying pressure on the two side tabs where screws were removed. Use a plastic opening tool as a lever to lift the drive out.
  7. Lenovo Edge 2-1580 Storage Replacement: 7 단계, 이미지 1/2 Lenovo Edge 2-1580 Storage Replacement: 7 단계, 이미지 2/2
    • Carefully, using your hand, remove the hard drive from the laptop.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Julian Escallon
회원 가입일: 09/27/17
714 평판
안내서 5개 작성하였습니다
USF Tampa, Team S14-G1, Boczar Fall 2017 USF Tampa, Team S14-G1, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G1
4 회원들
안내서 5개 작성하였습니다
댓글 3개
The Edge 2 requires a hard drive of 7mm or less or the bottom cover will not fit properly.
randylovely - 답글
Thank you, was looking everywhere to find that out!!!
christopher busse -
Thank you, your help was so useful.
Alejandro E Jecke - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 23
전체 시간: 4,100
