주요 콘텐츠로 건너뛰기
Lenovo Essential B570 DVD Drive Replacement
필요한 것
  1. Lenovo Essential B570 DVD Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn over laptop.
    • Switch open the left battery lock.
    • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
  2. Lenovo Essential B570 DVD Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Hold the right battery lock open with one hand while removing the battery itself with the other.
  3. Lenovo Essential B570 DVD Drive Replacement, Back Panel: 3 단계, 이미지 1개 중 1개
    • Loosen the five Philips screws that secure the panel.
    • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
  4. Lenovo Essential B570 DVD Drive Replacement: 4 단계, 이미지 3개 중 1개 Lenovo Essential B570 DVD Drive Replacement: 4 단계, 이미지 3개 중 2개 Lenovo Essential B570 DVD Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Prop open the cover with a plastic opening tool.
    • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
  5. Lenovo Essential B570 DVD Drive Replacement, DVD Drive: 5 단계, 이미지 1개 중 1개
    • Unscrew the one 4 mm Phillips screw that is securing your DVD drive to the frame.
  6. Lenovo Essential B570 DVD Drive Replacement: 6 단계, 이미지 2개 중 1개 Lenovo Essential B570 DVD Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Grab your DVD drive and pull outwards.
결론
작성자
2다른 기여자 명과 함께
Samuel Filliettaz
회원 가입일: 10/20/15
864 평판
안내서 5개를 작성함
UMass Dartmouth, Team 4-5, Catania Fall 2015 UMass Dartmouth, Team 4-5, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G5
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,326
