주요 콘텐츠로 건너뛰기
Lenovo Essential B570 Hard Drive Replacement
필요한 것
  1. Lenovo Essential B570 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn over laptop.
    • Switch open the left battery lock.
    • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
  2. Lenovo Essential B570 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Hold the right battery lock open with one hand while removing the battery itself with the other.
  3. Lenovo Essential B570 Hard Drive Replacement, Back Panel: 3 단계, 이미지 1/1
    • Loosen the five Philips screws that secure the panel.
    • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
  4. Lenovo Essential B570 Hard Drive Replacement: 4 단계, 이미지 1/3 Lenovo Essential B570 Hard Drive Replacement: 4 단계, 이미지 2/3 Lenovo Essential B570 Hard Drive Replacement: 4 단계, 이미지 3/3
    • Prop open the cover with a plastic opening tool.
    • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
  5. Lenovo Essential B570 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/3 Lenovo Essential B570 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2/3 Lenovo Essential B570 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 3/3
    • Pull the Hard Drive out of its socket.
    • Lift the tab upwards to remove the hard drive.
    • If you cannot pull the hard drive out of its socket, there is a possibility that there is a 4mm Phillips #1 screw securing it. Locate it and remove it before continuing. It is in very close proximity to the black tab.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Samuel Filliettaz
회원 가입일: 10/20/15
855 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 4-5, Catania Fall 2015 UMass Dartmouth, Team 4-5, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 4,745
