주요 콘텐츠로 건너뛰기
Lenovo Essential G555-0873 CPU Replacement
필요한 것
  1. Lenovo Essential G555-0873 CPU Replacement, Bottom Panel: 1 단계, 이미지 1/1
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lenovo Essential G555-0873 CPU Replacement: 2 단계, 이미지 1/1
    • Lift from the notch until the back panel comes up.
  3. Lenovo Essential G555-0873 CPU Replacement, Fan: 3 단계, 이미지 1/1
    • Disconnect the fan from the motherboard by pulling the plug shown in the picture.
  4. Lenovo Essential G555-0873 CPU Replacement: 4 단계, 이미지 1/1
    • Unscrew the three 4.6mm screws shown in the picture.
  5. Lenovo Essential G555-0873 CPU Replacement: 5 단계, 이미지 1/1
    • Gently lift the fan straight up until it is lifted out of the case.
  6. Lenovo Essential G555-0873 CPU Replacement, Heat Sink: 6 단계, 이미지 1/1
    • Unscrew the four 7.3 mm screws shown in the picture.
    • Note that springs are attached to the screws. Do not remove the springs.
  7. Lenovo Essential G555-0873 CPU Replacement: 7 단계, 이미지 1/2 Lenovo Essential G555-0873 CPU Replacement: 7 단계, 이미지 2/2
    • Pull the heat sink assembly out of the laptop.
  8. Lenovo Essential G555-0873 CPU Replacement, CPU: 8 단계, 이미지 1/2 Lenovo Essential G555-0873 CPU Replacement, CPU: 8 단계, 이미지 2/2
    • Use a flat-head screwdriver on the hinge shown, and turn counter-clockwise to the unlock position
  9. Lenovo Essential G555-0873 CPU Replacement: 9 단계, 이미지 1/1
    • Remove the CPU
    • There will be old thermal paste on the CPU and heat sink which should be wiped off using microfiber cloth.
    • Before putting the heat sink back in, a small droplet of thermal paste should be applied onto the center of the CPU.
결론
Michael Elledge
회원 가입일: 02/05/19
869 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 376
