주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
You can use this guide to remove the heat sink in for cleaning, replacement or to gain access to the CPU.
부품
지정된 부품이 없습니다.
  1. Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lift from the notch until the back panel comes up.
    • Lift from the notch until the back panel comes up.
  3. Disconnect the fan from the motherboard by pulling the plug shown in the picture.
    • Disconnect the fan from the motherboard by pulling the plug shown in the picture.
  4. Unscrew the three 4.6mm screws shown in the picture.
    • Unscrew the three 4.6mm screws shown in the picture.
  5. Gently lift the fan straight up until it is lifted out of the case.
    • Gently lift the fan straight up until it is lifted out of the case.
  6. Unscrew the four 7.3 mm screws shown in the picture.
    • Unscrew the four 7.3 mm screws shown in the picture.
    • Note that springs are attached to the screws. Do not remove the springs.
  7. Pull the heat sink assembly out of the laptop. Pull the heat sink assembly out of the laptop.
    • Pull the heat sink assembly out of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Elledge
회원 가입일: 2019년 02월 05일
869 평판
안내서 7개 작성하였습니다
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 53
