주요 콘텐츠로 건너뛰기
Lenovo Essential G555-0873 Heat Sink Replacement
필요한 것
  1. Lenovo Essential G555-0873 Heat Sink Replacement, Bottom Panel: 1 단계, 이미지 1/1
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lenovo Essential G555-0873 Heat Sink Replacement: 2 단계, 이미지 1/1
    • Lift from the notch until the back panel comes up.
  3. Lenovo Essential G555-0873 Heat Sink Replacement, Fan: 3 단계, 이미지 1/1
    • Disconnect the fan from the motherboard by pulling the plug shown in the picture.
  4. Lenovo Essential G555-0873 Heat Sink Replacement: 4 단계, 이미지 1/1
    • Unscrew the three 4.6mm screws shown in the picture.
  5. Lenovo Essential G555-0873 Heat Sink Replacement: 5 단계, 이미지 1/1
    • Gently lift the fan straight up until it is lifted out of the case.
  6. Lenovo Essential G555-0873 Heat Sink Replacement, Heat Sink: 6 단계, 이미지 1/1
    • Unscrew the four 7.3 mm screws shown in the picture.
    • Note that springs are attached to the screws. Do not remove the springs.
  7. Lenovo Essential G555-0873 Heat Sink Replacement: 7 단계, 이미지 1/2 Lenovo Essential G555-0873 Heat Sink Replacement: 7 단계, 이미지 2/2
    • Pull the heat sink assembly out of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Elledge
회원 가입일: 02/05/19
869 평판
안내서 7개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 145
