주요 콘텐츠로 건너뛰기
Lenovo Essential G555-0873 RAM Replacement
필요한 것
  1. Lenovo Essential G555-0873 RAM Replacement, Bottom Panel: 1 단계, 이미지 1/1
    • Unscrew the two 5.1 mm screws that secure the bottom cover.
    • Note that the screws will not come all the way out of the sockets.
  2. Lenovo Essential G555-0873 RAM Replacement: 2 단계, 이미지 1/1
    • Lift from the notch until the back panel comes up.
  3. Lenovo Essential G555-0873 RAM Replacement, RAM: 3 단계, 이미지 1/3 Lenovo Essential G555-0873 RAM Replacement, RAM: 3 단계, 이미지 2/3 Lenovo Essential G555-0873 RAM Replacement, RAM: 3 단계, 이미지 3/3
    • Push apart hinges shown in picture until RAM pushes itself up to approximately a 30 degree angle.
  4. Lenovo Essential G555-0873 RAM Replacement: 4 단계, 이미지 1/1
    • Pull the RAM stick out of its socket.
  5. Lenovo Essential G555-0873 RAM Replacement: 5 단계, 이미지 1/1
    • Push apart hinges of lower RAM stick until it pops up to a similar angle.
  6. Lenovo Essential G555-0873 RAM Replacement: 6 단계, 이미지 1/1
    • Pull out second RAM stick in the same way as the first.
  7. Lenovo Essential G555-0873 RAM Replacement: 7 단계, 이미지 1/2 Lenovo Essential G555-0873 RAM Replacement: 7 단계, 이미지 2/2
    • Push RAM sticks in diagonally, then push down and snap it in with hinges.
    • Make sure that the RAM stick is aligned with the notch on the port when inserting it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Michael Elledge
회원 가입일: 02/05/19
869 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 12
전체 시간: 245
